1 - 2 of 2 Posts
For those of you who's painted their calipers, would 1 can of VHT caliper paint be enough for all 4 calipers? Cause i don't want to buy an extra can and never use it and not be able to return it. Oh and how long does it take for one coating to dry? So i have an idea on how long it will take. Thanks.
i know for using the paint can style, it is 10-15 minutes per coat of paint. for a can, it could be the same, if not less. but when you have all 8 pieces off your vehicle at once (if you remove them) you should be fine if you go from the first piece to the 8th piece. then by the time you are done with round one, you will be ready to do a second and third if you want
1 - 2 of 2 Posts
