1 - 8 of 8 Posts
I've recently installed an oil pressure gauge and I was wondering what values people are getting. I'm just curious so I can compare them to my own.
@ startup -> about 75psi
Idle at temperature -> 15-20psi
Driving -> 45 - 55 psi, depending on RPM
on start ups mine is at around 110, and at idle its at 25 psi, i have never seen it go below 25 psi.
Mine sits right in with the first few posters. Your numbers look fine. Exact numbers will vary based on type/weight of oil used, type of filter used, how old the oil and filter are, and many other factors.
Discussion Starter · #6 ·
My oil pressure at idle is now stead at around 15psi. this is with stock oil and a stock filter. Just wondering if there is anything wrong with the oil pressure that low at idle.
Once the car is moving the pressure tops out at 55-60 psi just like before.
yeah, that's about what i'm getting with my oil pressure gauge as well... things look good to me (or at least a few of us have the same results so that's a good thing!)
1 - 8 of 8 Posts
