I changed all four spark plugs at 99K miles and noticed there's oil on the threads. I don't see any in the well or the base of the spark plugs. There's some crusty coatings near the nut area though. I googled and found there could be few causes below. I appreciate any comment or opinion on this issue. My car is not burning oil and I don't have any white smoke at the tailpipes. The old oil did smelled like gasoline every time I changed it.
Valve cover gasket - I replaced this at the same time as spark plugs.
Blown head gasket
Bad valve stem/guide seal
Damaged piston ring
Blown head gasket
Damaged piston ring
