1 - 20 of 23 Posts
i like the mobile 1 oil filter, or the stock motorcraft one is fine, or the k&N if you want to spend shitloads of money.
fram uses newspaper as filter material.
Fram is an example of a company that lives by its marketing department, and the reluctance of consumers to try and learn anything new.
Left is a stock OEM Sti oil filter. On the right is a Fram Toughguard replacement. Which one do you want filtering your engine?
And yes, thats cardboard and glue holding the fram filter media in place.
dayum LMAO puralotor any good found at advance auto goin napa later 2 day see what they have in stock
X
Guest
Thanks a lot man....i see the difference clearly.
Clearly the cardboard and glue is superior. That metal stuff on the left just adds weight to the car. Who needs it? :p
I haven't bought a Fram oil filter in nearly 10 years. I've pretty much stuck to Purolator PureOne when possible. I got my current MS6 filter from the dealer, but I'm open to alternatives.
I've seen a lot of filter test over the years and Purolater always finishes at or near the top. I think I once saw Purlator place second to the Mobil 1 filters.
Discussion Starter #10
thanks
hmmm... come to think of it maybe it IS superior. Don't judge a book.... :) you know how it goes.
As long as the cartboard and glue holds (and I assume fram did their R&D and it does hold) that design could potentially be better than the metal one. After all there is no glue between the filter element and the metal caps, meaning unfiltered oil can seep out in between. There can be no such seepage on the fram design....
just a though.
If you'd like to read about instances where the fram filter media has collapsed, and even one or two of complete filter failures...
Hit up the oil filter forum at
http://www.bobistheoilguy.com
Marketing and brand loyalty is the only thing that keeps fram alive. The only filter they've made in the past 15 years that has any sort of quality is the X2's.
If you want the polar opposite to fram, check out baldwin. They are much harder to find, but generally are considered one of the best spin-on full flow oil filters on the market.
Of course if you really get into discussions, there are some people who argue the full flow oil filters are pratically worthless and serve little or no function. (Which is why people theorize fram hasn't been sued into oblivion...as the car doesn't die if the filter goes into 100% bypass due to a collapsed center stack) If you actually want to filter your oil, you need to move to a bypass system.
K&N is all I use. It's worth the $10 for quality and easy access. (top nut)
You pay a shitload for your car, it's just not worth it to me speculating on the quality of other filters. :D
Advance Auto carries the Purolator filters, but you have to ask for the part number at the desk, the books aren't updated yet.
thanx for the link crossbow, but I don't feel like searching through the whole site trying to find those things. Can you provide a direct link?
Not really, there are literarly thousands of discussions. What type of discussion do you want to read specifically? Bob's search engine works pretty good.
Just search for full flow vs bypass in the filter subsection if thats the type of discussion you're looking for.
well, I was refering to what you said:
"If you'd like to read about instances where the fram filter media has collapsed, and even one or two of complete filter failures..."
1 - 20 of 23 Posts
