1 - 2 of 2 Posts
I have been asked before about an OIL FILTER Removal Tool or Wrench for the Mazda superseded
of the ORIGINAL OIL FILTER for ALL Skyactiv GASOLINE ENGINES, either 1.5 Litre, 2.0, and 2.5.
The Original now OLD Oil Filter was Mazda Part Number:
PE01-14-302 Oil Filter No Longer Parts Sold by Mazda Parts,
PE01-14-302A Oil Filter No Longer Parts Sold by Mazda Parts,
PE01-14-302B Oil Filter No Longer Parts Sold by Mazda Parts...
THE LATEST and NEW Genuine Oil Filter Worldwide is now Mazda Part Number 1WPE-14-302 Oil Filter.
Be aware these Oil Filters are SMALLER than the original, BUT is the Correct Unit to use and has the Correct By Pass Valve specification Installed.
The 1WPE-14-302 Genuine Oil Filter is for the following Mazda Models.
*Fit is for all Mazda Vehicles with SKYACTIV 4 Cylinder Gasoline:
(1500CC - 2000CC - 2500CC - Model Years...
for Mazda 2 2014 ~
for Mazda 3 2013 ~
for Mazda 3 2019 ~
for Mazda 6 2014 ~
for Mazda MX-5 2016 ~
for Mazda CX-3 2014 ~
for Mazda CX-30 2020 ~
for Mazda CX-5 2013 ~
for Scion iA 2016 ~ 2018 (Mazda made only).
for Toyota Yaris 2019 ~ (Mazda made only).
So IF you are looking for a Wrench Tool CAP to Remove the small 1WPE-14-302 Oil Filter when it comes to replacing I can confirm the Toyota listed unit fits perfectly, available from eBay and other on-line sites and is Not Expensive.
It's part number is called a H901, 14 flats, 64.5mm and is less than $5.00...click on blue.
From eBay
NOTE: While many owners will sometimes install what they believe are a better alternative Oil Filter because it is 'what brand I used before', or is a 'larger capacity oil filter', PLEASE DO NOT install and or use just any OIL Filter which is not Mazda tested.
Simple reason is there has been many cases where 'a' different brand Oil Filter installed and owner then gets dash warning CEL lights and DTC's
(Diagnostic Trouble Codes) because these 'other' oil filters are not up to Mazda Specifications.
Anyway here are pics I personally took of the Genuine Mazda replacement Oil Filter and the H901 Removal Tool Cap Wrench.
These 1WPE-14-302 MAZDA oil filters are very small, but the Cap Wrench fits very snugly on the Oil Filter casing and it's 14 flutes and works perfectly.
239217
239218
239219
239220
Discussion Starter #2
OIL FILTER CAP WRENCH for Mazda 1WPY-14-302
The TURBO Skyactiv Gasoline Engines uses a different Part Numbered Genuine Oil Filter.
New Part Number is 1WPY-14-302
While it appears to have 14 Flute Flats I can not confirm 100% that this Cap Wrench listed above
will work as it should, I am almost certain it will as these Turbo Oil Filters are slightly LONGER in size and no larger in Diameter than the 1WPE-14-302.
For the 2500CC TURBO Engine used..
for Mazda 6 2018 ~
for Mazda CX-5 2019 ~
for Mazda CX-9 2016 ~
1 - 2 of 2 Posts
