I plan on doing an oil change by myself on my 04' 6s in the next couple days with full synthetic and I'm wondering what brands you guys use?
And I need 6 quarts?
I know the manual tells you to us 5w30 but I've seen some posts here and elsewhere where people recommend to use 5w20 instead. Any reason for this?
Thanks.
I have a 2004 Mazda 6s and my oil fill cap states to use 5w-20. I have used 5w-20 every since I have owned the car, but recently switched to 5w-30 since I just passed 100,000 miles. I will probably switch to 10w-30 once I hit 130-140,000 miles. I just want to slowly progress to thicker oil as the car gets older, seals start to go bad, etc. To answer your question, there is really such a small difference between 5w-20 and 5w-30. The 5w-20 was specified by Mazda, so that they could squeeze out another .333 MPG due to federal regulations (less friction than 5w-30 oil). I would just go with a 5w-30 oil as it will offer slightly better engine protection, and you aren't going to notice the .333 mpg decrease. As for what oil, I would recommend Mobil 1, but you will probably hear 10 different oils from everyone else on this forum, and they will all probably be good oils too. I would STRONGLY recommend going with a WIX or MOBIL oil filter if you have them available in your area. I was using FRAM high mileage oil filters for awhile, but recently realized how crappy they are. I switched to WIX, and the moment I held the filter I could feel how much better made it was. My oil does not seem to get dirty as quick with the new WIX filter. And yes, you need 6 quarts.
since im replying using my cell phone ill make it short...
the manual recomends quality 5.5 or6qts of 5w20 oil; castrol, mobile,valvoline, motorcraft,etc...
personally, im still trying diff oils before i settle with one brand and weight. as a habbit, i change my oil and filter every 3 mos(3-4000miles). keep in mind losing around1 qt of oil every 3000miles on our cars is considered normal and if your pcv ever goes bad, that amount of oil loss will increase.
after saying all that, as of this month im using motorcraft 5w20 syn blend and motorcraft FL820S filter and loving it so far!
