1 - 10 of 10 Posts
Does anyone know if the reader on the first page of this link will work with the 6? Is this a good price?
http://members.shaw.ca/DL0006/flyer_english.pdf
And attached is an image for you amusement that I found in the catelogue.. yes, I'm immature :D
the club already has a scanner that works with the 6
I know, but I had assumed it was in the GTA, which is a bit of a drive. I had been planning on getting a non-cpe intake, so i thought having a scanner would be good.
I also wouldn't have to bother whoever has it if it happens often..
Paul. I need to borrow the scanner... can you please ship it to me?
Just kidding :)
Might as well go out an buy my own.
Your info says waterloo and the scanner is in vaughan
Unless you want to spend that much money
Ours was way more expensive than the one listed there
I'm not going to seach the flyer, but there is one that is CAN compliant too that PAuto was also selling.
I bought this one when it was on sale for $250:
CTC obd II Can
It tells you the exact problem that the computer is detecting.
Also that scanner will not work with the Mazda6.
thanks, that's what i needed to know.
If you are still intersted, I can get you a connection to a profesional grade OBDII CAN compliant scanner for $450 from the manufacturer.
1 - 10 of 10 Posts
