The OBD-II port is simply clipped into the dash panel. Look up under the dash at the OBD-II port. On each side, you will see a clip. Press in on the clips and the OBD-II port will pop out. You can then place it anywhere you'd like.Has anyone in here found an easy way to move the OBD-II port? I am trying to record some info while I'm driving but my connector from AE is so big it covers my break pedal.
Thanks for the info! My AE from RPM will be here tomorrow...can't wait to data log on the 17" screen!The OBD-II port is simply clipped into the dash panel. Look up under the dash at the OBD-II port. On each side, you will see a clip. Press in on the clips and the OBD-II port will pop out. You can then place it anywhere you'd like. [/b]
