im doin an a/f gauge now. im unsure what wire is the signal wire. anyone have a diagram or konw what wire i need to tap into? thnx for your help
There is a reason they use heavily shielded wires to the 02 sensor. I have seen narrow bands that want you to tap into the ecu wire that gets the signal from the 02 sensor, but never one that told you to tap by the sensor itself.
no not by the sensor. it says to tap further up by the wire harrness. I just realised anyway. My gauge wont work with a wide band.when cpe come out with there down pipe is it possible to put an extra bung and put in a narrow band o2 sensor? or is it too much work and i should just forget about it.
