1 - 7 of 7 Posts
And i cannot find any clear instructions on how to install that metal bracket to the negative battery terminal, Or where to ground the wires FOR A 6I NOT A 6S before any smark comments start coming..
Is there something I am Missing here? Appreciate any insight thanks...
check the 2nd or 3rd page
http://www.clubatenza.com/forum/viewtopic.php?t=76&start=0
I have a general Idea...Just having two issues.
The metal bracket that they say you should put over the negative battery terminal....how would you fit that over the terminal keeping it secure. Not moving around?...
Where on the engine on the passengers side of the vehicle is the grounding point on the 6i? area looks alittle different on an I than an S.
All the engine Layouts with grounding points you see are all on 6s's....It doesn't help a guy with an I out at all...
1 - 7 of 7 Posts
