1 - 20 of 20 Posts
i noticed this today, i punched it in 1st gear to merge quickly into traffic and ran the needle past 6k and the car engine rattled quite a bit.... i noticed after i shifted into 2nd gear that there was a plume of smoke behind me :eek:
is this a sign of bad lifters? :huh:
hard to tell, i know white smoke means coolant and blue smoke means oil... it wasn't 'billowing' so i'll say it was the latter...
Have you checked your oil lately? I'd do that just to make sure the pcv valve isn't busted and sucking oil.
i got a question
i was under the impression u didnt get great gains from the injen+maf customizer
i saw this on ur cardomain
Injen Cold Air Intake, good for an additional 22HP & 24ft/lbs @ 5,100RPM at the wheels!!!
is this true?
[snapback]556762[/snapback]​
actually, i checked it after i posted... i'm down about 1 quart in 3k miles :irate:
.....Why is it that every single time that I read one of these threads I have to run outside and check my oil level?....
Discussion Starter #13
Originally posted by crossbow@Nov 14 2005, 04:50 AM
Ya sounds like your PCV valve is going.  I'd get that replaced immediately.  Or at least inspect it.  I honestly wouldn't drive the car till its fixed.  More then one engine has died on the forums due to a bad pcv valve.
http://forum.mazda6tech.com/viewtopic.php?t=3998
[snapback]556836[/snapback]​
:eek: dang, i need to check that ASAP...
probably gonna get the oil changed today anyways so it will be topped off... how much do the PCV valves cost?
Discussion Starter #15
Discussion Starter #17
well, i added a quart to the crankcase tonight, it could use another 1/2 quart! :swearin:
going to the dealership tomorrow as i can't find any PCV valves at the local AutoZone, plus it should be warranty replaced! :irate:
we may want to sticky this issue, i'm only at 37K miles :tear:
Discussion Starter #19
Originally posted by crossbow@Nov 15 2005, 10:06 AM
Its a CRP on 6tech.  I could repost the CRP here, and ask it to be sticky'd.  CRP's and TSB's and such are also posted on the front page of 6club.  (Linked to 6tech's).
[snapback]558054[/snapback]​
k thanks... i'll keep you guys posted, if this is related to the PCV (as we're thinking) it's probably a good time for eveyone to check their valves!!
1 - 20 of 20 Posts
8 Participants
crossbow
