This guide is an addition, not replacement, to the original noob guide. This has been updated with more recent data:
*Note: I am leaving the guide in this format, without in-depth explanations because it is imperative for everyone to research and read on their own. There is too much knowledge to compile into any one guide, but feel free to ask questions once you have read and feel unsure on something.
In order to properly enjoy your Mazdaspeed6, you should first ensure all preventative maintenance is done. This is for increased reliability, but also for trouble-free life down the road.
Compression Test
Before doing anything, you should perform a compression test; kits are available to rent for free from any auto parts store. This will tell you the "health" of your engine, and tells you there are no leaks. Below are the Factory Service Manual (FSM) instructions and acceptable ranges. The point of this test is that no reading is under 130psi, and that the variance between cylinders is not higher than 28psi.
*Note - continuously crank until the needle stops rising
Turbo and VVT/Timing Chain
The turbo is prone to smoking, especially once you modify the exhaust components. Mazda has extended its warranty to 70k miles, details can be found at the following link:
OFFICIAL Warranty Extension Program on turbo and VVT Actuator
The real "fix" is to swap the turbo out, all the other fixes are simply patching the issue.
Example:
Also, the VVT/timing chain will fail on this engine, which Mazda also has extended its warranty on. The only place which should do this repair would be a Mazda dealership, or a very reputable shop.
The TSB document can be found in the above link, and further info below if you want to inspect it yourself (remember to search for even more info):
*NOTE* Additonal info for new owners can be found here:Noob Guide
Preventative Maintenance
• Change out all your vehicle’s fluids, there are how-to's and info for each one on this forum:
Fluid Notes & DIY Pictures
o Engine Oil
o Transmission Oil
o Front Differential/Transfer Case Fluid
o Rear Differential Fluid
o Brake Fluid
o Power Steering Fluid
• Clean your EGR valve and tube
How-To clean your EGR
• Clean your valves
How to Clean Your Valves
Carbon Build Up Info
• Swap your Spark Plugs to 1 step colder (even on a stock car), and gap to .032"
Spark Plug Info
Spark Plug Swap
Additional, and highly recommended:
• Delete the EGR Valve, or unplug it
Injector Seals & EGR Delete
• Install an oil catch can and swap the PCV valve
OCC Install
OCC Install 2
Change PCV Valve
• Rear engine mount upgrade (crucial, even if staying stock)
How to Swap Engine Mounts
Now, with those items done, you should proceed to modify your car, if desired.
The first, and only mod, which is absolutely crucial to fully enjoying your MS6, is a COBB Accessport tuner. This device saves, then, replaces the stock ECU tune on your car, it is not a simple piggyback tuner. This device allows for customizing all values and controls on the car's ECU, if you wish to do a custom tune, but COBB also provides basic maps/flashes, for those just looking for an easy upgrade. The drivability and reliability of your car will vastly improve with this tuner. Even if you plan to stay stock, I highly recommend the tuner.
**The COBB AP is the only tuner which I recommend, all others are greatly inferior**
**For EU folks, Veratuner is the equivalent to the COBB AP**
You may purchase the AP new from many sources online, including eBay. Simply search for the product code "AP-MAZ-002" (this is the previous version, the main difference is the display on the "AP3-MAZ-002" AP, no tuning aspects are different), and purchase from a reputable vendor. A fair price is ~$275-$350 for a used V2 AP (mazdaspeedforums.com has a large classifieds section, you must pay for access). The V3 AP is ~$650 new.
LINK TO OFFICIAL WEBSITE-COBB ACCESSPORT
When buying used you MUST ensure it is “unmarried” before buying. I advise you get a picture showing this, with the user's name/date/forum on a piece of paper along side, prior to buying. It will show:
The benefit of having the tuner as the first mod, is that it allows the car to be optimized for any future mods, so your car is always running at the top of its game. It also allows you to monitor the car, so you can be certain everything is in good shape.
COBB classifies their tunes in 3 stages:
• Stage 0- A car without any mods, only a COBB tune
• Stage 1- A car with air intake and/or intercooler, and/or turbo inlet pipe upgrades
• Stage 2- A car with an upgraded CDFP (cam driven fuel pump), and either an upgraded downpipe (replaces both OEM catalytic converters), or a test pipe (replaces the first OEM catalytic converter)
COBB OTS maps and info- Accessport Off The Shelf Maps
*The Tuning Section is also filled with knowledge:
http://forum.mazda6club.com/303-atr-engine-tuning/
Before going Stage 2,
You must replace the CDFP (cam driven fuel pump) internals to avoid the risk of fuel cut from the increased load on the engine system. Some have even experienced fuel cut on Stage 1, however, the only way to know you are okay is to data-log using the COBB AP and verify fuel pressure is above 1600 during WOT (wide open throttle) runs.
Vendors for internals
I personally only recommend the following 2 vendors for internals, both with the best track records:
• HPFPupgrade- lifetime warranty
Mazda DISI Do It Yourself Pump Internals | HPFPUpgrade.com
• AutoTech- the “big” guys
Autotech High Pressure Fuel Pump Internals for MS3 & MS6
How to swap the internals out, there are also many other guides and videos online as well:
CDFP Internals install guide.
Krystm's Garage – Mazda 3 Mods and More! Cam Driven Fuel Pump (CDFP) Internals Install
You may also buy a complete fuel pump, but it is much more expensive.
Options are, with the first being preferred due to better warranty:
Mazda DISI Complete High Pressure Fuel Pump | HPFPUpgrade.com
MZR DISI 2.3 HPFpump? | Custom Performance Engineering
*Note: Our forum custom E-tuner is @TiGraySpeed6, he can vastly improve on the off-the-shelf COBB tunes, not only adding power, but also reliability.
Now, you may proceed to add additional modifications as desired.
*Note: You can mod the car without a tuning device, however, it is not recommended. The most you should mod this car without a tuning device would be the aforementioned stage 1 mods.
Useful links:
http://forum.mazda6club.com/mazdasp...mps-noob-thread-summary-guide-new-owners.html
FAQ-links to important threads
HOW-TO DATABASE MS6 - Mazdaspeed Forums
SEARCH, READ, & SEARCH AGAIN – Knowledge is power
Compression Test
Example:
- HOW-TO VVT - Mazdaspeed Forums
- Pics of Failure/how to inspect it yourself
- Example of timing chain rattling against the valve cover *Note- You will only hear it on a dead cold engine on the first start*
http://www.youtube.com/watch?feature=player_embedded&v=6xYLHFBqp2o
o Engine Oil
o Transmission Oil
o Brake Fluid
• Clean your valves
Spark Plug Info
Spark Plug Swap
OCC Install
OCC Install 2
Change PCV Valve
Useful links:
