Hey Guys,
I have a 2004 Mazda 6 with de V6 engine, manual transmission. About 4 months ago i've changed the clutch from the dealer because i had to change it. (136 000Km)
A month ago, while I was at the stop sign, I tried to put the first gear but it did want to engaged + lot of noise from the tranny. So i've called the towing and the inspection reveals damage to the clutch it self and the transmission! When everything was down, they told me that the clutch disc was touching the bell housing, because the bellhousing is made of aluminium it has heated and expend so I could'nt clutch anymore, bearing had heated on the shaft. So i've changed the transmission & the clutch.
2 weeks ago, SAME PROBLEM, SAME THING. I went to see 3 different specialists, they never saw this before and could'nt explain what happened...
Transmission is new (8 000km)
Clutch kit is brand new (excedy clutch)
No loose on the crank
flywheel is perfect, no vibration and has been refaced each time.
Have you ever experience this kind of problem??
see pictures attached
