Well, after a week of not having my speed, I finally got it going again today.
I had a mishap with my dealership - they put a hole in the boot and stripped my passenger side ball joint.
Since finding a new one and getting it shipped for an install before Labor Day Monday was almost impossible, I had to go with a Moog Problem Solver adjustable ball joint. It's adjustment range is -1 degree to +1 degree. It adjusts by rotation which means it also adjusts caster either positive or negative. The unfortunate thing is there are some ratios that you have to deal with because of it's circular motion. I put them on and adjusted them with less caster - which allows a little bit better turn-in in corners. I still need a final alignment, but so far I like it. You may ask why then did I not get it fixed until today? The instructions that came with the ball joint said to torque the bottom stud nut to 121 ft pds of torque.
Seemed excessive to me, but it was in the instructions. Needles to say the ball joint was ruined.
After reordering the ball joint to get it replaced under warranty - with an extra to replace the drivers side one - Advanced Auto's computer system screwed up and I did not get them until today. I know I could have gotten another SPC by this point, but after seeing it in my hand, I was interested to see this different ball joint in action. After taking off the driver's side ball joint, I'm glad i did order 2 because the threads were starting to round on that one as well. Never have a tech align your car and tighten the ball joints with the biggest guy with the biggest breaker bar he can find!:huh:
