Replying to Topic 'new track times'
I'm going to throw in my 2cents here, but I'm not sure if it's worth anything...
First, there are many variables with drag racing. One of these variables is the total weight of the vehicle at the time of the race. The 6s w/ manual transmission (MTX) weight, as per Mazda and without the driver, is 3243 lbs. Now a 6s w/ automatic transmission (ATX); again as per Mazda and without the driver, the weight of the car is 3311 lbs. Throw in the driver. Who weighs more? Weight can be an overlooked factor.
The power plant of the 2 cars is the same V6. One is modified a little more than the other, but by looking at the dyno charts from the modified V6 ATX and the stock V6 MTX, the HP difference is 6.4whp and 2.6lb-ft of torque, with the modified motor having the upperhand of course (got dyno info from MSDSinc.com and Brillo's dyno chart).
Then that leads to the power delivery. One is a 5-speed automatic and the other is a 5-speed manual transmission. As per Mazda, the first 3 ratios are 'shorter' on the MTX than the ATX. 4th and 5th gears are pretty damn near close (it's a rarity to use 4th and 5th in a drag race with times slower than 14secs.). So, shorter ratios = less time for the motor to rev and the less time it takes for the motor to get to it's peak power. It looks like this is demonstrated on the 330' times as the MTX reached 330' at a little less than half a second faster than the ATX.
At the 1/8th mile, the MTX is faster by .166 secs. But look at the MPH at the 1/8th mile. The MTX is 5.89mph faster than the ATX, also showing that the MTX's shorter ratios have reached higher speeds in a lesser amount of time than an ATX.
The 1000' time shows that the MTX is still faster by 1.154 secs... showing again, that the MTX has reached a faster speed and is travelling at more feet per second than the ATX in a shorter amount of time.
And then you have the 1/4 mile time. 15.282 @ 88.37mph for the MTX and 15.986 @ 88.01mph. The MTX is faster by .704 secs. but why the similar trap speeds? Maybe it's because the MTX reached 88.37mph in LESS TIME for a quicker 1/4mile and the ATX probably took the WHOLE 1/4mile to reach 88.01mph. Factor in the weight and I'll be willing to bet that the MTX, overall, weighs less than the ATX 6... Now, I'm not saying that you are overweight Kris.
The other variables could be the weather, the elevation, the driver, track conditions, and whatever else I missed.
But, I maybe dead wrong about this entire reply.... So please, someone, kill me, if I am....
