1 - 3 of 3 Posts
I just replaced my bad engine with a JDM one that I have ordered recently.
I dressed the jdm engine with all the proper sensors and pieces to make it identical with the usdm engine. I did double checked every single connector from the wiring harness and they are all pluged in.
I trying to start the car but it doesn't start.
The engine crank well , it seems to want to start but dies instantly.
I double checked the spark plugs , they seem fine and they were working in the old engine.
The coil is ok.
Gaz in each cylinders.
I was wondering if those car need a base map reset in the ecu or any pre-setting need to be injected into the ecu.
I have done many Honda swap but this is my first Mazda.
Any one can help me out , please !
Between , the car was running but it had a rod bearing problem . It took me about 3 days to change the engine. I guess the ECU was reseted...
Discussion Starter #2
I have figured out the problem.
I will post some pictures because it might happen to one of you sooner or later.
The intake cam has a cam angle sensor located to the back of the engine.
The usdm engine that was originally installed in my Mazda 6 was equipped with 5 tooth as a reference for the sensor.
The JDM engine that i received had only 1 teeth at the end of the cam.
So it means that the calibration of the cam angle sensor is different between JDM and USDM PCM.
I have swapped the cams.
Voilà, Problem solved.
Merci
i believe the focus cams only have the one tooth...wonder if the jdm guys can swap out their cams then?
good info
1 - 3 of 3 Posts
