This info from Trey Cobb copied from the Cobb Forum:
Looking like a Monday release guys. We can't release on a Friday and there was more testing necessary than usual. We've moved over to a new code repository system since the last release so the developers wanted to do a higher degree of testing than normal to verify everything was working as expected. Don't want to grenade any ECUs.
Here is a sneak peek of the release notes:
New Features:
A toggle is available to switch the ECU from using the Load Dynamics table to instead use the Boost Dynamics table. What this means is instead of the ECU tweaking the WG Duty cycle based on Load Error (difference of Desired Load against Actual Load) it will instead control the turbo based on Boost Error (different of Desired Boost against Actual Boost).
Finally a toggle is added to activate the Load Target table. This just enable a more simplistic Load Target functionality for the ECU so instead of using all the various potential gear based and other logic driven Load Target tables it simply pulls the target from the single Load Target table and runs with it.
Both those toggles have been added to assist you all with stable boost control. Of course you don't need to use them and the system will continue to operate 100% as before.
Cheers,
Trey @ COBB
New Features:
- Tuner Auto Updater
- Users can accesss tuner software updates through the "Help/Updates" menu.
- Users will no longer have to download the latest tuner version to stay up-to-date.
- Rollback - users also have the ability to rollback to the previous release of Tuner by using the "Help/Updates/Rollback last update" option.
- Added AP MGR 2.0 Installer
- Added HPFP Control Tables (BETA)
- HPFP Desired Pressure - Max A
- HPFP Desired Pressure - Max B
- HPFP Desired Pressure A
- HPFP Desired Pressure B
- HPFP Desired Pressure C
- HPFP Desired Pressure ECT Comp
- Added Knock Tables (BETA)
- Knock Retard - Decay Magnitude A
- Knock Retard - Decay Magnitude B
- Knock Retard - Decay Rate A
- Knock Retard - Decay Rate B
- Knock Retard - Multiplier
- Knock Retard - Offset
- Knock Retard Active - Min ECT
- Knock Retard Active - Min Load A
- Knock Retard Active - Min Load B
- Knock Retard Active - RPM (Max)
- Knock Retard Active - RPM (Min)
- Added Radiator Fan Tables (BETA)
- Radiator Fan - ECT Thresholds
- Radiator Fan - Voltage Compensation
- Added MAP Sensor Scaling Tables (Sesnor Cal. Tables)
- MAP Scalar for EM - Component A
- MAP Scalar for EM - Component B
- MAP Scalar for EM - Offset
- MAP Scalar for Log - Component A
- MAP Scalar for Log - Component B
- MAP Scalar for Log - Offset
- MAP Scalar for OBD - Component A
- MAP Scalar for OBD - Component B
- MAP Scalar for OBD - Offset
- Added Ignition Compensation Tables
- Ign BAT vs ECT Comp. - % Used
- Ign BAT vs ECT Comp. A
- Ign BAT vs ECT Comp. B
- Ign Low Octane Reduction
- Ign Per Cylinder Comp.
- Increased Boost Pressure Logging Limit
- Increased limit to log boost pressure above 24 PSI.
- Fixed MIL Defeat
- MIL defeat implementation has been corrected for 06-07 MS6, 07-08 MS3, and 09 MS3.
- See "Edit\Advanced Engine Parameters\Toggles(Base)" for complete list of defeatable codes.
- Fixed Live Tracing
Cheers,
Trey @ COBB
