21 - 28 of 28 Posts
Discussion Starter #22
Yesterday I put a dehumidifier in the garage. This morning the car fired right up.
Moisture is getting into something.
Discussion Starter #23
Tried to start it again after an hour and same problem. I removed that first ground connection (close to the negative battery terminal) and sanded away the paint. Then everything was cleaned with a wire brush and sand paper (everything.)
Well that sucks. Keep us posted on what it was. It may help someone else out in the future.
Discussion Starter #26
And it's back. The shop said it was a bad terminal clamp on the positive battery cable. The part was $4.99. It looked perfectly fine to me.
Bad terminal clamp?!? To think that you have gone to all that hassle when it's just an easy fix!
Well, who am I to speak? I had one experience to my old car that it won't start. I left it overnight to a shop and got it the following morning. They won't charge me for the fix. After two days, the car won't run again. The lights are coming on but won't start. I called for help. The guy checked the starter and it's good. Every relay is also good. It was by "chance" when he found out that I have a loose ground terminal to my transmission.
I think that's why the shop won't charge me for the fix last time. I suspect that the car started when they checked it.
21 - 28 of 28 Posts
4 Participants
Archerfish
