HELLO PEOPLE, I MAY HAVE A BIG PROBLEM. i JUST INSTALLED HID IN MY 2005 MAZDA 6 I, AND I WAS ADJUSTING THE LOW BEAM LIGHTS TO GO UP BECASUE THE LIGHTS WERE FACING THE GROUND TO MUCH AND I COULDNT SEE IN FRONT OF ME WHEN I WAS DRIVING. I DID THE DRIVER SIDE AND EVERYTHING WORK PERFECTLY AND WHEN I WENT TO THE PASSENGER SIDE, I WAS ADJUSTING THE LOW BEAMS TO GO UP AND I HEARD A CLICK NOISE AND I NOTICED THAT THE LOW BEAM LIGHT WAS FACING THE FLOOR. NOW MY DRIVER SIDE LIGHT IS UP AND MY PASSENGER SEIDE LOW BEAMS ARE FACING THE GROUND. WHAT SHOULD I DO?:mad::mad::mad:
If you've broken something inside the headlight housing you probably going to have to rig up a way to keep the bulb in place. Can you see what broke? is their peices?
Get back in there and take a closer look.
