1 - 7 of 7 Posts
Going to install my MagnaFlow cat-back exhaust next week.
I've read on various posts that one should disconnect the battery prior to the installation.
I'm having a hard time imaging what for. Changing a couple of mufflers without tampering with anything else just doesn't compute. No pun intended.
Does the engine sense a diffeence in back pressure or A/F ratio?
I suppose I'll have to reset all 36 presets (SAT 1, 2, 3/FM1,2/AM) on the radio too. :swearin:
Please chime in if... you know the real reasons.
John :cool:
the car's computer will be out of whack because the Magnaflow changes the amout of volume of exiting air flow. The idea of disconnecting the battery is for safety / insurance issues and also for re-setting the car's air flow tables...I would say "it is for real" and not just bs...
Word... :yesnod: By disconnecting the power source it commands the computer to recalibrate upon re ignition. Kinda like a re-boot for your computer. Besides, what could it hurt.
Well I'm not one to go against experience.
Disconnecting the battery will cause a loss of radio presets. Right?
Just want to make sure I write down all my settings if needed.
John :cool:
Simple solution to your problems...
Go to an auto parts store and get a memory saver. This is a little cigarette lighter adapter that has a 9-volt battery attached. The battery provides a trickle charge that is strong enough to keep all memory on your stereo, but will still provide the same desired effects for resetting the computer.
I paid $5 from Snap-on and use it every time I play with my car.
Kastar Memory Saver
1 - 7 of 7 Posts
