1 - 3 of 3 Posts
Ok so I’ve have a 2006 Mazda 6 and only half of the lcd is reading. The radio has come on twice but when this happens the temp in right hand corner of screen is showing then I know that the radio will work. I’ve changed just about everything but the same issue. I’ve changed the lcd out the radio wire connections like only the clock works but everything I changed I didn’t even have to. I’ve had the same problem since I got the car 2 months ago. Please help
Welcome to the forum!
Go Patriots! :D
Unfortunately, it sounds like a classic LCD issue that the 1st generation was plagued with. Search around on here because there's a TON of threads about attempts to fix it and ways to work with it. Ultimately, however, your best bet is to swap it out with a properly working one, which isn't very difficult.
1 - 3 of 3 Posts
