1 - 3 of 3 Posts
Hey everyone
I have a 2004 6i sedan.
The switch I use to pop open the fuel door is stuck. I've tried spraying it with lubricants but it is stuck tight.
Has anyone else had this issue?
Any suggestions?
Thanks!
Brandon
email: [email protected]
Not sure what you mean by switch, 07 uses a lever to pull for release. If your car does not get above freezing in Canada, it may be froze and lube may not help then. If that is the case, try hair dryer where you think it could be stuck, probably at fuel door mechanism. I believe you can get access in the trunk.
1 - 3 of 3 Posts
