Can't really explain it.....
Strangely my Car radio started making these ticking noises, like a small surge of eletrical flow is heard when I turn my Volume up on the stock Radio system.
Today My radio Shut off for a second, and then came back on, and kept doing that while I was driving. When I put the car in park in front of my house, the Car shut off then back on meter needles moving all the way to the right side, and all the cel lights on.
This shit hasn't started happening since I did the throttle body mod grounding the engine....Maybe that could be the problem I dunno... :swearin:
............ u might want to unplug the power wire u used to ground the TB and see what happens....
any time you have problems after a mod i'd assume the mod, or work invovled with install.
I've already spoken my piece about TB grounding, but anyway...
Since that mod does absolutely nothing, I would doubt that it is the problem.
But, like mk706 said, it could be related to the work done installing it.
Do you have access to an OBD-II scanner? It may be time to head to the dealer and get the CEL code...
just un do the mod and see if it fixes it
