I have a 2006 Mazda 6. It was running perfect. I parked it and the next morning I started it up and about 2 min later it died. No rough idle or anything just died. It turns over but will not start. Any advice
Hello, welcome to the forum.
Which engine/trans do you have?
1st, does it have fuel?
2nd, were there any codes present?
3rd, did you check all relevant fuses for engine and fuel systems?
After that it comes down to either fuel or spark.
Is your battery strong and getting good cranking speed?
What fuel are you using and what is the temperature there?
Pull a lead off the coil pack(one where top is closest to metal, left rear from memory)
Crank it and look for spark coming from coil pack where lead is out.
If you got spark, it most likeky will be fueling issue.
2.3 automatic. Code said maf sensor replaced that and still won't start. Checked all the fuses and it has fuel
