1 - 17 of 17 Posts
Some local mazda people were holding a dyno day there and i took mine in to see what i can do. it was pretty hot and dusty that day. Mods are MSCAI, Synapse BPV, SU TIP, ETS 3.25 TMIC, CPE-RMM, Custom Catback and a wrong AP OTS map(wrong intake, closest one i can get). During the run the guy said i was knocking from 5500-6600rpm. Some tuning will net more hp there. Dyno was done on a Dynapack. 91 Octane fuel.
296.0AWHP @ 6134RPM
335.7lb/ft @ 3652RPM
Once i get a scanner i will scan it and post the dyno sheet here. Meanwhile enjoy the video : )
run video
The guy also said to stay away from shell gas for some reason. They knock like crazy.
UPDATE:dyno sheet on post #13
gives me hope... i have similar mods but full TBE and MBC/map clamp @18psi... no tune
I was just on a dynapack yesterday and hit 251/285 with almost identical mods except no AP/tune... this gives me ALOT of hope, lol.
not sure how you could be knocking from 5500-6600 rpm when the knock sensor goes def around there, unless it was audible knock. if that was the case then i hope they stopped.
good question, not sure if it was audible knock or not. They did look at some other graph on the computer and told me i was knocking. If it was audible i believe and hope they did stop it there and then.
Wait, you mean SU TP, not TIP, right? Because those numbers are awfully high for not having a TP/DP. (Stage 1)
Oh wait, you said stage 2. But those dynapacks do run kinda high, right?
It just varies man, heres a graph from a member off 6crew (i believe this was done on the same day as the OP's) who has a CAI/BPV/ground kit, then his buddy who had a stock MS6 pulled a 250/291 (no grpaph)
This image has been resized. Click this bar to view the full image. The original image is sized 777x600 and weights 64KB.
Compared to my graph with mods in my sig...
Discussion Starter #10
I have the TIP(intake inlet pipe) and i do not have a TP/DP. I need to get a scanner so that i can put the print out here.
thouse are hell of great torque numbers for your mods, i cant wait to see the scans of your dyno run
Them numbers are great and you dont even have a DP/TP either. Very nice...
Discussion Starter #13
sorry for taking so long, i have been on vacation and now i cannot find anyone with a scanner.
So i took the two scans with my camera, hope it comes out well.
Hey man, nice numbers. Did you stop by Pro Drag whilst you was back in KL? Too bad I was in UK man!
Discussion Starter #15
Sorry i didnt have a chance when i was in KL, i went there for the thomas cup(badminton) and hurried back to penang where i was staying. BTW i am back in usa now..pity no chance to look at your car.
i should be going there again soon. hopefully we can meet then.
Hey cokonut, I was the beta tester for the map that you are running and I have the most up to date version (Stage2+TIHSF 91 v103f+TMIC) before I got my ProTune from Tim. If you would like it, send me your email.
that makes me real curroius of what I will dyno. Since I have very simalar mods. But I go to a dynojet that has high numbers.
1 - 17 of 17 Posts
