1 - 9 of 9 Posts
Mobil 1 ATF now includes both T-IV and Mercon V under the applications it is "suitable" for:
Mobil 1 Synthetic ATF
I've never really understand why mixing Mercon V and the factory fill T-IV led to the Aisin transmissions being destroyed, especially since many of the quasi-universal ATF's list both specs on the bottles (redline D4, castrol multi-import, etc...). That said, the transmission fluid was changed on my '05 wagon before I picked it up from the used car lot, and for all I know they could have flushed out all of the T-IV and put in Mercon V. I'd never be able to tell by looking at the dipstick.
I'm planning on doing a drain and fill with each oil change since these transmissions are known to run hot. I was thinking about using a universal synthetic fluid, such as Redline D4 or Mobil 1, to avoid transmission failure related to the mixing of Mercon V and T-IV.
Has anyone run Mobil 1 synthetic ATF in their Aisin unit since it was reformulated to include the T-IV spec? It's a bit cheaper and easier to find than the Redline.
I did a drain and fill with Mobil-1 about 6 months ago and have suffered no issues. This was at 50K miles and I did a second drain and fill at my next oil change. At the time, Mobil-1 syn ATX fluid was taken off the shelves in CA due to a chemical in it being illegal in the state. I went ahead and did the second drain and fill with Amsoil syn ATX fluid.
Since doing the two consecutive drain and fills the trans has been working very well.
I also have used the Mobil-1 ATX synthetic in my 2004 6, runs just fine. I installed a transmission cooler on it at the same time, runs like a charm with 98k miles on it.
To the person who asked how often you should change, I'd recommend every 90k-100k, but you could probably get 120k out of it if you REALLY wanted to. A lot of people change theirs at different times, it's really what you just feel like doing.
90k-100k? I thought it was more like 30k-60k....
I've also flushed and filled with Mobil 1 ATF. Only about 3-4k miles, but no issues.
1 - 9 of 9 Posts
