I am a proud new owner of a white MS6 here in Las Vegas. Generally the only gas you can find in town is 91 or lower. Today I found a Rebel gas station close to home that sells Unleaded 100 octane for $4.99 a gallon. I have noted the other posts which talk about expensive octane boosters for $17.00 a bottle. I have had the flash and still notice ocassional power loss (alot less than before the re-flash), but I want to know what the effect of filling the car with 50% 91 octane and 50% 100 cotane would be? Is it a simple average of the two octanes (50%@ 91 plus 50% 100 / 2) = 95.5 octane. Please help as I think this may be a cheaper way for me to make 93+ octane for my MS6 instead of using 91 octane piss gas.
Please help. Thanks
If you go to rocket brand fuels.com they have a octane mixing chart. Hope that helps. Plus you can find where it is sold in your state
All I run in my car is 100+ unleaded, but I don't do much driving in it....
Octane boosters are a joke, they raise tenths of an octane, not an actual octane point...
Let your car run low on gas, and go and put in about half a tank of 100 (Which at $4.99 is a very good deal)... and run the car... you will notice an immediate difference.... I notice mainly in throttle response and spool up....
Anyways, definately try it out...
The short answer is yes, it is just a weighted average of the volumes and octane ratings of the two fuels. 1/2 and 1/2 will yield 95.5 Octane. 93 Octane can be had by adding about 2 gallons of 100 Octane to 8 gallons of 91. When you buy 89 at the pump, the pump mixes 91 and 87 in equal amounts for you, the stations don't atually stock an 89 Octane fuel.
Thanks for your responses. I did try and there is a noticeable differnence in pick up. I have found a cheap way to make 93+ octane gas. Thanks for your help guys.
I love this forum.
