81 - 100 of 514 Posts
Finally, my contribution here:
My first set of wheels: 16x6.5 and heavy!
I then went to this, which is what I wanted when I bought the car: the Euro look.
However, the 17's are stupidly heavy. Wanting something lighter, I went to 16x8 +50 FD wheels.
They rub with anything, even 225/50/16. It was then I learned that larger wheels fit wider tires because the sidewall bulges less; that's why 225/40/18 fits more easily than 225/50/16's.
The light, wide 16's were so damn fast, I bought a second set for autocrossing and mounted tiny tires on them. The car got really damn fast from an 8% gearing reduction:
Wanting something that looks better, I sold a set of FD wheels and went bigger. After all, all the "cool guys" here were recommending it. Here are 18x8 +50's:
They rub with 235/40/18's and probably 225/40/18's. They also are slow and stupid.
Thus, I went to nicer looking lightweight 16's. Here's the car with 16x7.5 +50's. I run these today, and still have a set of FD wheels to race on:
For the record, 18's suck and they will never go on my car again. I hated them.
The good wheel combinations are, in my opinion, 16x8, 17x8, and 17x8.5- with either 245/45/16 or 245/40/17 rubber up front. Rubber in the rear can be skinnier to aid in getting the tires to heat up evenly.
Here is the close (questionable?) fitment of 245/45/16 racing tires up front on 16x8 +50's:
225/50/16 in the rear on 16x8 +47 (I run a 3mm spacer):
Finally, this is why there is so much discrepency between what people fit on their cars:
Left to right, that's a 245, 235, and 225mm wide wheel. Which looks skinniest to you? Not that 225, that's for sure.
In conclusion, I've had many sets of wheels and tires. Anything other than stock has required a fender roll. If someone tells you otherwise, perhaps they are not running very aggressive tires.
rims: 5Zigen Hyper 5ZR 18" hyperblack -> 18x7.5 +48mm offset
tires: Toyo Proxes 4 -> 225/40/18
suspension: Tein basic coilovers
fender: no rubbing, roller not needed
compared to stock.
OEM Wheels-Chrome dipped 17"s on Michelin Pilot 50's
TEIN 1.5 drop kit
Stock wheels have Negative offset so it helps to keep the space.
NO RUBBING Unless I put on 18's,then I have to go down to a 35-30 series tire to prevent rubbing with any lower offset.
I have another set of rims but don't have any pics with those ones yet...coming soon.
Drifz 515GM 18x7.5 48mm offset
225/40/18 Kumho Ecsta 711 tires
tires rub occasionaly on hard cornering or when ppl are in the back.
fenders are gettin rolled this winter
Here are mines
Sokudo 10 18x7.5 +48 offset
Falken Ziex 225 40 18
Springs: MazdaSpeed
Fenders not rolled, and no rubbing
these are my babies! kinda hard to see the detail when they are clean, though. 225/45R18. rubs slightly in the back if i hit a bump going fast or if i have a lot of passengers in the back and hit a bump. no springs.
This is not a thread for discussion, so please post only if you are putting up information. Any posts not strictly on topic for this thread will be deleted. Questions about a member's setup should go through PM to that member. [/b]
Kazera KZ-V 17x7 +50 offset with Avon Tech M550 A/S 225/45/17. Mazdaspeed springs. No rub. Had entire guitar setup in the rear hatch and took acouple corners and it didnt rub. I will probably roll the fenders anyway just to be extra safe but this combo is rub-free without a roll.
Sorry been away for ages. Here are my new shoes. (Its the rainy season, so I'm too lazy to wash the car!)
[attachmentid=10006]
Rays Gram Lights 57S
17 x 7.5 +48 Offset
Fenders have been rolled, no rubbing whatsoever even with people in the back seat.
VTTR front rotors installed but that's another story.
Tires: Goodyear Eagle F1 (Forgot which model). 225/45/R17
Rims:
5Zigen FN01R-C 17x7" +48mm
Tires:
215/50/17 Michelin Pilot HX MXM4 (yeah, the stock ones :( )
Dropped about 5lbs per corner.
Been on for more than a month and no rubbing at all. I've had 2 people in the back and drove pretty hard with no problems.
Not lowered...yet. MS springs are on the way. :)
[attachmentid=10564] [attachmentid=10565] [attachmentid=10566]
Wheels:
Tenzo R GT-5
18x8
+45mm offset
Tires:
Falken ZEIX-ZE 512s 225/40/18
Springs:
Eibach pro kit
Fender: No rubbing (with 8" width, 3 kids in back, and a drop!). Rolling not necessary. Trimmed the plastic under the rear fenders as a precaution only.
Wheels: SSR comp 17X8 48 offset
Tire: Advan Neova 225/45/17
Coilovers: d2
Rub: Fenders rolled, but rubs on hard cornering. Didn't roll far enough.
RX7 FD3S 16" 15lb 50mm offset wheels.
dunlop sp sport 8000 in the foreground, yokohama AV db2 in the back. 225/50/16
:D
there's a slight bend in one of the wheels, but i dont give a shit, these are track only. im not quite sure what tires im gonna put on there though. i'll post pics of them on the car once i get new tires
396 Participants
audiofreak19
