41 - 60 of 514 Posts
Wheels:
PIAA 2-Piece Super Rozzas
18 x 7.5 +48
21.5 lbs.
60mm lip
Tires:
225/40 18 Toyo Proxes 4
No rubbing; no fender roll. Will probably roll fenders once I lower it (looks like it has enough clearance once it's dropped so we'll see).
Enkei RSV 17" X 7"
+42 offset
Toyo T1S 225/45 17
there is a bit of rubbing in the back with people in the backseat. I'm rolling my fenders this weekend. No drop...yet.[attachmentid=2957]
Tires:
225/40/18
Wheels:
5ziegen Super Six
18x7.5
48 offset
Springs:
Mazdaspeed
Shocks/Struts:
Koni
rubs a little on outer lip of wheel with weight in back.
Looking for a place to roll the rear.
EDIT : Rolled :yesnod:
Velox Hyperion 19x8 45 offset
falken 502 225/35/19
eibach
fender rolled
no rub
Zenetti Five 19x8 40 offset
toyo proxes4 225/35/19
eibach
fender rolled completely
no rub
E
Guest
here is a set of Konig Holes 19x8.5 +48
currently there are NITTO's on it (I rubbed (actually mor like CUT) the hell out of them) .. thinking about getting some Dunlop FM's 225/35-19
Motegi ff7 glossy black with crome lip.
45+mm.
225/40/18 .
Goodyear Essenza tires.
Eibach lowering spring.
Rubbed like crazy. Rolled fender with a rubber hammer(Mallet. I think thats what its called). Worked like a charm.. I also used a heat gun and accidentally burned the rug under one of the wheel wells so now it hits that but no damage to tire. LOL :)
ASA AR-1 Aluminum Wheels 18 x 7.5 Yokohama 225/45/18 Tires Mazdaspeed Springs for hatch/wagon
NO rubbing, will show lowered version of wagon, when return from business trip.
19x7.5" ADR GT SPORT (hypersilver)
+45mm offset
225/35/19 BFG SCORCHER TIRES
EIBACH Pro-Kit
FIRST to ROLL FENDERS (from my first rims)!
[attachmentid=4650]'03 6s A/T... Factory Size was 205/60/16
I have Ion type 131 18 x 7.5 45mm offset with 225/40/18 Kumho Ecsta ASX. I had a little rubbing on the rear, but rolled the metal in the wheel well. Looks good and no more rubbing.
Nate6s
Originally posted by scary admin person@Jul 6 2005, 10:58 AM
This is not a thread for discussion, so please post only if you are putting up information. Any posts not strictly on topic for this thread will be deleted. Questions about a member's setup should go through PM to that member.
[snapback]448969[/snapback]​
Directions, follow you will.
18"x7.5 5Zigen FN01R-C (Bronze)
+48mm offset
Pirelli PZero Nero (not to sure about tire numbers)
Not rolled
No drop, but no rub. Asked the person about lowering springs, he said no rub guaranteed.
Kosei K1-TS
17"x7"
+50 Offset
Fuzion Zri Tires
205/50/17
MazdaSpeed Springs
No Rub
Zinik Adrian's 18" +42 offset- Rub on harsh bumps. Need to be rolled
[attachmentid=4789]
[attachmentid=4790]
[attachmentid=4791]
Rota Subzero 17 x 7 | Royal Black | +45 Offset | Yokohama AVS ES100
- Rubs on harsh bumps only with 4 passengers. . . fender needs to be rolled
- Overlooked the center hub bore size.. had to bore the rims out a bit. (dad did it)
- other than the center hub problems. . which are entirely my fault. the rims are nice. :drive:
396 Participants
audiofreak19
