1 - 20 of 514 Posts
DISCLAIMER: Just because one member did not experience rubbing with a specific wheel/tire combo, that doesn't mean that you won't either. Individual results may vary based on the type of driving you do and your suspension setup.
OK, so the idea here is for everyone that has changed their wheels or tires, etc to post up what they have, include pictures if you like. This way if anyone has questions about what will fit and what won't, they can see what everyone else has done and get ideas.
This is not a thread for discussion, so please post only if you are putting up information. Any posts not strictly on topic for this thread will be deleted. Questions about a member's setup should go through PM to that member. Also please note that if you do not post information with the wheel, the post will be deleted. Include the name/brand, size, and offset.
If you're not sure about one of the specs for the wheel, you can try looking at http://www.wheelspecs.com
I'll start with an example using the stock wheel setups: (info taken from Doc Roadster)
OEM 16in wheels
Tires:
205/60/16 - North America
205/55/16 - Everywhere but North America
Wheels:
Mazda OEM 16x7
+55mm offset
Weight:
21.1lbs
OEM 17in wheels
Tires:
215/50/17 - North America
215/45/17 - Everywhere but North America
Wheels:
Mazda OEM 17x7
+60mm offset
Weight:
21.1lbs
Reading Topic: Members Wheels
GramLights 57pros
Wheels:
18x7.5
+52 offset - fit fine w/ no rubbing
Tires:
225/40-18 Toyo T1-R
About 43lbs per corner. I think the rims are about 19.5 lbs each
Eibachs Lowering Springs
I drove pretty hard with them on too. Next time I'll try 225's.
I'll post pics when I get my cam back.
[Here is a picture until you get the ones of your car - MG]
Wheels: Volk GT-U 18 x 7.5 +50 offset
Tires: Pirelli P-Zero Nero 225/40/18
Springs: H&R Sport
No rubbing, no fender roll.
Stock RX-8 wheels
18x8
Tires:
225/45/18
Sprint Lowering Springs
Replying to Topic 'Members Wheels'
ASA AR1
Wheels:
18x8
+35mm offset
Tires:
Dunlop SP 9000 225/40/18
springs:
eibach pro kit
fender:
had to be rolled as far as possible, rear wheel wells had to be slightly pulled. No rubbing.
Motegi MR7
Wheels:
18x7.5
+45mm offset
Tires:
Kuhmo 225/40/18
springs:
Stock
fender:
Have not rolled, and only rubbed once with people in back and going into a steep driveway
Wheels:
SSR GT7s 18x8
+48 offset
Tires:
Toyo Proxe4 225/40/18
Springs:
Stock
Fenders:
Rolled
Here is mine. 18x7.5 Maxxim Eracer wheels +45 offset with 215/40/18 Yokohama Parada Spec 2 tires. Max grip tires.
This is with a Eibach drop and no fenders rolled. No problems with rubbing.
Enkei RSV
Wheels:
18x7.5
+45mm offset
Anthracite metal finish
Tires:
Falken Ziex 512 215/40/18
springs:
Stock (for now; Eibachs soon!)
fender:
Have not rolled, and has never rubbed. Might change once Eibachs are installed
Wheels:
ALT-296 (Blades)
18x7.5
+42mm offset
Tires:
Nitto Neo Gen 215/40/18
Springs:
Eibach Pro-kit
Fender:
Does not rub at all with Eibach. Did not roll the fender.
Wheels-
Exel TZ-10's
18x7.5
+45 offset
Tires-
Yokohama ES100
225/40ZR18
rubbed badly with eibachs, rolled fenders. no rubbing with almost 2" drop on coilovers
Just got my wheels on today:
G-Racing Kuma (Hyper Black)
48 18x7.5 Offset 225/40/18
Rubbing: Looks like they will probably rub when I get my lower job done (really close).
Pics soon...
My rims:
Kosei K1 TS 17"s
Offset: +50
My Tires:
Tires: Yokohama AVS dB 2
Rubbing: They do not rub at all, however, the tires to overlap with the rear fender. I think if I put enough weight in the back they would rub, even with the high offset and only 225 width.
Pics:
R
Guest
Wheels: ADR M-Sports (Hyperblack) - 18x7.5 +48mm offset
Tires: Michelin Pilot Sport - 225/45/18
Spings: Racing Beat
No Rubbing so far (about 1500 miles on this setup)
5Zigen FN01R-C (The lightness - yeah baby!)
17 x 7", 48 offset
Toyo Proxes T1-S
225/45-17
Stock 16" combo with substntially worn tires weighed 46=47 lbs, the new set weighed in at an approximately 10 lbs saving per corner :)
No rubbing including some VERY hard driving ;) Not lowered, not that that would matter AT ALL - if its going to rub, it would have!
I've had 2 people in the back and stuff in the trunk - no issues.
And a final closeup ...
Falken Torque 5
18x7 +42 Offset
215/40/18 Hankook Ventus Sport K104
Does not rub. No Fender Rool needed
Car was once fitted with 18x8 +35 offset but those rubbed on rear wheels.
1 - 20 of 514 Posts
