has anyone bought a set of these?
will these eat away the stock shocks :(
http://www.mazdausa.com/MusaWeb/speedDispl...mp;categoryId=4
mine's an 04 hatchback 2.3L
i assume i should ge tthe 5dr right?
any ideas or opinions on these?
http://forum.mazda6club.com/index.php?show...daspeed+springs
I highly suggest you check this link out and read up on it for it contains more info than Ben Stein's brain!
For the 8,956th time.... to summarize:
If you have a 6s V6 engine, sedan OR hatch OR wagon, get the HATCHBACK/5DOOR SPRINGS.
Members have posted pictures of each model with these springs on......... search for them. I even did a huge writeup why and posted pictures to back it.
If you have a 6i I4 engine, sedan OR hatch, get the 4CYL SEDAN SPRINGS.
Under NO circumstances should anyone order the V6 sedan springs. The rear sags like a mofo.
This quote is so powerful that if you don't believe me then you need to check out more links!
This link will give you an idea of the MS springs if you feel the need to know without searching on your own...Good Luck!
http://forum.mazda6club.com/index.php?showtopic=58329
after all the explanation, 1 thing I don't get
isn't the hatch springs designed for the hatch stock shox though?
would it look weird if I put the hatch on hatch?
no it will look tight :D
i have the MS springs on stock shocks, like mentioned before you will be fine but eventually the stock shocks will wear down a little quicker than if you had stock springs....
from what i have read it all depends on driving style.... I mean you will eventually have to replace the stock shocks, i plan on doing mine next spring w/ Koni Yellows....
