1 - 7 of 7 Posts
and what offset are they?
they're 18x8, 8kg's for the gunmetals... but what is the offset on these wheels?
Not sure on the offset. I'll see if I can get Mazda to tell me.
Wheels are $457.50 each. Center caps are $22.50 each. Install kit is $4.50.
there's an install kit? what do you need to install the wheels...? don't you just mount the tires... take the old wheels off, put the new ones on, torque them to the right amount, and then you're done?
its hubcentric rings..and it might be lugs too...i can't recall.
The offset is +40mm.
Unless the speed6 has wider fender flares than the regular 6, they will not fit without rubbing. The offset is too low
yeah, that's what i figured, i was hoping they were +50 like the standard rx8 wheels
1 - 7 of 7 Posts
