Hi all not long had my 2006 mazda 6 TD sport (143) Ive got a lot of oil coming from inside my cam cover. Im guessing its either cam or crank seals. Can this be changed if you take the timing belt off? Shes due a belt change so don't wont to be taking th eengine apart for a seal replacement.
Due to this problem the DPF has started flashing , also the car is in limp mode. (Engine light on) For some reason I have the trackson control light on to
Thanks all =]
Thanks all =]
