1 - 16 of 16 Posts
· Premium Member
A good reference for the Check Engine Light (CEL) codes for Mazda 6i.
::edit:: link is dead, so here's the info -Tea
Mazda 6i I4 (L3) Cel Codes
DTC TABLE [L3]
´: Applicable
¾: Not applicable
DTC No. Condition MIL DC Monitor item Memory function Page
P0011 CMP timing over-advanced ON 2 CCM ´ (See DTC P0011)
P0012 CMP timing over-retarded ON 2 CCM ´ (See DTC P0012)
P0031 Front HO2S heater circuit low input ON 2 O2 sensor heater ´ (See DTC P0031)
P0032 Front HO2S heater circuit high input ON 2 O2 sensor heater ´ (See DTC P0032)
P0037 Rear HO2S heater circuit low input ON 2 O2 sensor heater ´ (See DTC P0037)
P0038 Rear HO2S heater circuit high input ON 2 O2 sensor heater ´ (See DTC P0038)
P0101 MAF sensor inconsistent with TP sensor or engine speed ON 2 CCM ´ (See DTC P0101)
P0102 MAF circuit low input ON 1 CCM ´ (See DTC P0102)
P0103 MAF circuit high input ON 1 CCM ´ (See DTC P0103)
P0106 MAP sensor performance problem ON 2 CCM ´ (See DTC P0106)
P0107 MAP sensor circuit low input ON 1 CCM ´ (See DTC P0107)
P0108 MAP sensor circuit high input ON 1 CCM ´ (See DTC P0108)
P0111 IAT circuit performance problem ON 2 CCM ´ (See DTC P0111)
P0112 IAT circuit low input ON 1 CCM ´ (See DTC P0112)
P0113 IAT circuit high input ON 1 CCM ´ (See DTC P0113)
P0117 ECT circuit low input ON 1 CCM ´ (See DTC P0117)
P0118 ECT circuit high input ON 1 CCM ´ (See DTC P0118)
P0122 TP sensor No.1 circuit low input ON 1 CCM ´ (See DTC P0122)
P0123 TP sensor No.1 circuit high input ON 1 CCM ´ (See DTC P0123)
P0125 Excessive time to enter closed loop fuel control ON 2 CCM ´ (See DTC P0125)
P0126 Coolant thermostat stuck open ON 2 Thermostat ´ (See DTC P0126, P0128)
P0128 Coolant thermostat stuck open ON 2 Thermostat ´ (See DTC P0126, P0128)
P0131 Front HO2S (stuck low) ON 2 CCM ´ (See DTC P0131, P0132)
P0132 Front HO2S (stuck high) ON 2 CCM ´ (See DTC P0131, P0132)
P0133 Front HO2S circuit malfunction ON 2 O2 sensor ´ (See DTC P0133)
P0134 Front HO2S circuit no activity detected ON 2 CCM ´ (See DTC P0134)
P0137 Rear HO2S circuit low input ON 2 CCM ´ (See DTC P0137)
P0138 Rear HO2S circuit high input ON 2 CCM ´ (See DTC P0138)
P0140 Rear HO2S circuit no activity detected ON 2 CCM ´ (See DTC P0140)
P0171 Fuel trim system too lean ON 2 Fuel ´ (See DTC P0171)
P0172 Fuel trim system too rich ON 2 Fuel ´ (See DTC P0172)
P0222 TP sensor No.2 circuit low input ON 1 CCM ´ (See DTC P0222)
P0223 TP sensor No.2 circuit high input ON 1 CCM ´ (See DTC P0223)
P0300 Random misfire detected Flash / ON 1 or 2 Misfire ´ (See DTC P0300)
P0301 Cylinder No.1 misfire detected Flash / ON 1 or 2 Misfire ´ (See DTC P0301, P0302, P0303, P0304)
P0302 Cylinder No.2 misfire detected Flash / ON 1 or 2 Misfire ´ (See DTC P0301, P0302, P0303, P0304)
P0303 Cylinder No.3 misfire detected Flash / ON 1 or 2 Misfire ´ (See DTC P0301, P0302, P0303, P0304)
P0304 Cylinder No.4 misfire detected Flash / ON 1 or 2 Misfire ´ (See DTC P0301, P0302, P0303, P0304)
P0327 Knock sensor circuit low input ON 1 CCM ´ (See DTC P0327)
P0328 Knock sensor circuit high input ON 1 CCM ´ (See DTC P0328)
P0335 CKP sensor circuit malfunction ON 1 CCM ´ (See DTC P0335)
P0340 CMP sensor circuit malfunction ON 1 CCM ´ (See DTC P0340)
P0401 EGR flow insufficient detected ON 2 EGR ´ (See DTC P0401)
P0402 EGR flow excessive detected ON 2 EGR ´ (See DTC P0402)
P0403 EGR valve (stepper motor) circuit malfunction ON 2 CCM ´ (See DTC P0403)
P0420 Catalyst system efficiency below threshold ON 2 Catalyst ´ (See DTC P0420)
P0441 Evaporative emission control system incorrect purge flow ON 2 Evaporative ´ (See DTC P0441)
P0442 Evaporative emission control system leak detected (small leak) ON 2 Evaporative ´(DTC P0442)
P0443 Evaporative emission system purge control valve circuit malfunction ON 2 CCM ´(DTC P0443)
P0446 Change over valve (COV) (EVAP system leak pump) stuck close ON 2 Evaporative ´(DTC P0446)
P0455 Evaporative emission system leak detected (gross leak) ON 2 Evaporative ´(DTC P0455)
P0456 Evaporative emission system leak detected (very small leak) ON 2 Evaporative ´(DTC P0456)
P0461 Fuel gauge sender unit circuit range/performance ON 2 CCM ´ (See DTC P0461)
P0462 Fuel gauge sender unit circuit low input ON 2 CCM ´ (See DTC P0462)
P0463 Fuel gauge sender unit circuit high input ON 2 CCM ´ (See DTC P0463)
P0480 Fan relay No.1 control circuit malfunction OFF 2 Other ´ (See DTC P0480)
P0481 Fan relay No.2 and No.3 control circuit malfunction OFF 2 Other ´ (See DTC P0481)
P0482 Fan relay No.4 control circuit malfunction OFF 2 Other ´ (See DTC P0482)
P0500 Vehicle speed sensor (VSS) circuit malfunction ON 2 CCM ´ (See DTC P0500)
P0505 Idle control system malfunction OFF - - - (See DTC P0505)
P0506 Idle control system RPM lower than expected ON 2 CCM ´ (See DTC P0506)
P0507 Idle control system RPM higher than expected ON 2 CCM ´ (See DTC P0507)
P0550 PSP switch circuit malfunction ON 2 CCM ´ (See DTC P0550)
P0564 Cruise control switch circuit malfunction OFF 1 Other ´ (See DTC P0564)
P0571 Brake switch circuit malfunction OFF 1 Other ´ (See DTC P0571)
P0601 Internal control module memory check sum error ON 1 CCM ´ (See DTC P0601)
P0602 PCM programming error ON 1 CCM ´ (See DTC P0602)
P0604 PCM RAM error ON 1 CCM ´ (See DTC P0604)
P0606 ECM/PCM processor ON 1 CCM ´ (See DTC P0606)
P0607 Control module performance ON 1 CCM ´ (See DTC P0607)
P0610 Control module vehicle options error ON 1 CCM ´ (See DTC P0610)
P0638 Throttle actuator control range/performance ON 1 CCM ´ (See DTC P0638)
P0661 Variable intake-air system control solenoid valve circuit low input OFF 2 Other ´(DTC P0661)
P0662 Variable intake-air system control solenoid valve circuit high input OFF 2 Other ´(DTC P0662)
P0703 Brake switch No.1 circuit malfunction ON 2 CCM ´ (See DTC P0703)
P0704 Clutch switch circuit malfunction ON 2 CCM ´ (See DTC P0704)
P0850 Neutral switch circuit malfunction ON 2 CCM ´ (See DTC P0850)
P1410 VAD control system circuit malfunction OFF 2 Other ´ (See DTC P1410)
P1562 PCM +BB voltage low ON 1 CCM ´ (See DTC P1562)
P2004 Variable tumble control system (VTCS) shutter valve stuck open ON 2 CCM ´ (See DTC P2004)
P2006 Variable tumble control system (VTCS) shutter valve stuck closed ON 2 CCM ´ (See DTC P2006)
P2009 Variable tumble control solenoid valve circuit low input ON 2 CCM ´ (See DTC P2009)
P2010 Variable tumble control solenoid valve circuit high input ON 2 CCM ´ (See DTC P2010)
P2088 CMP actuator circuit low ON 2 CCM ´ (See DTC P2088)
P2089 CMP actuator circuit high ON 2 CCM ´ (See DTC P2089)
P2100 Throttle actuator circuit open ON 1 CCM ´ (See DTC P2100)
P2101 Throttle actuator circuit range/performance ON 1 CCM ´ (See DTC P2101)
P2102 Throttle actuator circuit low input ON 1 CCM ´ (See DTC P2102)
P2103 Throttle actuator control motor circuit high input ON 1 CCM ´ (See DTC P2103)
P2107 Throttle actuator control module processor ON 1 CCM ´ (See DTC P2107)
P2108 Throttle actuator control module performance ON 1 or 2 CCM ´ (See DTC P2108)
P2119 Throttle actuator control throttle body range/performance ON 2 CCM ´ (See DTC P2119)
P2122 Accelerator pedal position (APP) sensor No.1 circuit low input ON 1 CCM ´ (See DTC P2122)
P2123 Accelerator pedal position (APP) sensor No.1 circuit high input ON 1 CCM ´ (See DTC P2123)
P2127 Accelerator pedal position (APP) sensor No.2 circuit low input ON 1 CCM ´ (See DTC P2127)
P2128 Accelerator pedal position (APP) sensor No.2 circuit high input ON 1 CCM ´ (See DTC P2128)
P2135 Throttle position sensor No.1/No.2 voltage correlation ON 1 CCM ´ (See DTC P2135)
P2138 Accelerator pedal position (APP) sensor No.1/No.2 voltage correlation ON 1 CCM ´ (See DTC P2138)
P2228 BARO sensor circuit low input ON 1 CCM ´ (See DTC P2228)
P2229 BARO sensor circuit high input ON 1 CCM ´ (See DTC P2229)
P2401 Evaporative emission system leak detection pump control circuit low ON 2 Other ´ (See DTC P2401)
P2402 Evaporative emission system leak detection pump control circuit high ON 2 Other ´ (See DTC P2402)
P2404 Evaporative emission system leak detection pump sense circuit malfunction ON 2 Other ´ (DTC P2404)
P2405 Evaporative emission system leak detection pump sense circuit low input ON 2 Other ´ (DTC P2405)
P2406 Evaporative emission system leak detection pump sense circuit high input ON 2 Other ´ (DTC P2406)
P2407 Evaporative emission system leak detection pump sense circuit intermittent ON - Other ´ (DTC P2407)
P2502 Generator terminal B circuit open OFF 1 Other ´ (See DTC P2502)
P2503 Generator output voltage signal no electricity OFF 1 Other ´ (See DTC P2503)
P2504 Battery overcharge OFF 1 Other ´ (See DTC P2504)
How about for the 06 Speed6? Do you have the CEL code listing?
2 Jax6S
I looked at link and there is no description what causes it.
At mazda workshop manual I found all descriptions what causes each CEL. And how to fix it fast if it possible. So once again - do you need official workshop manual or not ?
PS. I have Speed6 too...
2 Jax6S
PS. I have Speed6 too...[/b]
Can u send that to me Koya if you have that manual for the 2.3 I-4. That would be really helpful. Thx
Found this in another forum....
P2504 Battery overcharge OFF 1 Other[/b]
:rolleyes:
If anybody wants or need the Shop manual for the 03-05 mazda 6i MZR email me. I have it in PDF. i will forward it to you. It lists all the CEL codes and how to trouble shoot and repair them.
:rolleyes:Hello I have a 2004 Mazda 6 the 2.3 litter and i read your post and i would like to know if you can sent me the repair shop manual for the codes. I thank you in advance
· Premium Member
No new wheels or tires. I just been researching these codes and yes it looks like 3 of the 4 TPMS sensors hit the brick. I've had a problem with them for awhile, were the TPMS light will blink in the instrument cluster but all tires are within specs. The TPMS light(on clock work)goes off when driving home from work everyday, so theirs $200 in replaement parts.
Thank you for your assistance
· Premium Member
No problem
Hey all,
I just replaced my catalytic converter and the o2 sensors. My engine light at first stated my catalytic converter needs to be replaced. now I am getting code P0302 and P0171. When I went to Autozone the solution was to "reprogram the ECM (Engine Control Module)". Any idea on how to do that? Is it simply just unplugging the battery, waiting 10-15mins and plugging it back in?
1 - 16 of 16 Posts
