1 - 20 of 26 Posts
I tried searching...but
I was looking for the real wiring diagrams
for the 6 but all I can find is the workshop manuals. :swearin:
I'm mainly looking for the designations for the pins on the instrument cluster and
the entire wiring harness to the steering column (combo switch, ignition and steering wheel).
Any leads?
Best I can do.
Instrument Cluster
[attachment=27164:va177522.pdf]
Audio Controls
[attachment=27161:va182247.pdf]
Ignition Switch
[attachment=27165:va176659.pdf]
Wiper/Washer Stalk
[attachment=27166:va177308.pdf]
Combo Switch
[attachment=27167:va177318.pdf]
Headlight Switch
[attachment=27168:va177359.pdf]
Best I can do.
Instrument Cluster
Audio Controls
Ignition Switch
Wiper/Washer Stalk
Combo Switch
Headlight Switch
[attachment=27168:va177359.pdf][/b]
Thanks, but I managed to pick up a manual thats a little more in depth than the ones above.
I seem to have about 70pgs worth of wiring in color.
So if anyone needs help just drop me a pm.
Whats the info for?
M
Guest
Whats the info for?[/b]
I'm looking for a wiring diagram for a DENSO navigation system (I bought one from a crashed mazda 3 MPS)...can anyone help me??
Thanks
DENSO Unit.: K4238; fabricated on May 2006
Mazda Ref.: BR2C 66 DF0 B
My car.. Mazda 3, Model.: Exclusive, Date.: 2006
So if anyone needs help just drop me a pm.[/b]
I would like to get some better wiring of the headlights. My sons MAzda 6 lost low beams, front marker lights recently. High beams and driving lights okay though.
Frank
I'm looking for a wiring diagram that will show me where the wire from the passenger side low beam headlight leads to. Does anyone have this information?
Hello does any one have the P/N of the Denso Navigation Model K4238? please
or the cable pinout for the 24 pin RGB lines i have plug n play conenctors i would like to make a video interface harnes to bring video to the front screen thank you
does any one know what the modem under the dash that connects into the steering coloum is for?
It's not a modem. It's a port to plug-in a diagnostics scanner, or even a monitoring/scanning tool like ScanGuage.
info
can anybody get me a wire diagram for the info screen for a 2005 0r newer vehicle i change the radio to the 07 model and the info screen seems to have a diffrent plug so what wires do i splice to get the info screen working , please any help
there is like 8 wires to plug in i belive there is , power , constant , ground , illumination turn on and some other wires
1 - 20 of 26 Posts
