PNs and info to add to the con'FUSION!!! Well, hopefully reduce it some!
2006-2009 FORD 3.0 L 6 CYL ENGINE 6E5E-AA ATKDFWZ (VIN 1) 2006-2009 Ford Fusion(06-09), Milan(06-09), Zephyr(06) DURATEC (V6 CYL)
FORD 3.0 06-09 ENG 183/3.0
FI, GAS, MFI, DOHC, 24Valves, Ford(EngineMfr), Duratec, SFI(FuelSystDesi.), T- cover cast
#6E5E-BG
Block Casting: 6E5E-6015-AA
Right Head Casting: 3M4E-6090-CE
Left Head Casting: 3M4E-6C064-CE/CF
Crank Casting: VI60
Casting Location: Bell Housing Top
Years: 2006-2009
Model: Fusion(06-09), Milan(06-09), Zephyr(06)
Hollander: 9184
Special Notes: Duratec,Dohc 24 Valve,Aluminum Block And Heads,V6
Help info: Dohc 24 Valve,Duratec, Aluminum Block, Block Cast # 6e5e-Aa, Head Cast
#3m4
Help info: Roller Rocker Arms, Oval Intake Ports.
INV Help: Timing Cover Cast # 6e5e-6c086-Bg
Chain Drive Cams, 42 Teeth Cam Sprocket.
Water Pump Driven Left Exh Cam, V.V.T. On Intakes
Upc Code: 653517260742
