1 - 19 of 19 Posts
Mazda6club.com: Sponsors
Mazda 6 License Plate LEDs
License plate bulbs are used to illuminate the rear license plate on your Mazda 6. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
Newer luxury cars use LED modules to illuminate the license plate with modern, cool white light. By changing your license plate bulbs to LED, you can easily add this luxury look to your Mazda 6!
The installation is 100% plug-and-play, just replace your factory bulb.
This is one of the best, easiest modifications you can do to improve how your Mazda 6 looks at night.
HP5 Cool White Installed​
Brightness:
Diode Dynamics offers several bulb options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
SMD2: Slightly higher brightness than OEM bulbs. (24 lumens)
HP3: Much brighter than OEM bulbs. These are bright! (56 lumens)
HP5: Nearly triple the brightness of stock OEM bulbs! (92 lumens)
Bulb Design:
SMD2: Compact design, with two 5050-size Epistar SMD chips, driven at high power for maximum effective brightness. Outputs at 180 degrees.
HP3: One high-power SMD under a diffusing lens for truly even output (no hotspots). Constant current design and air-cooled base for superior reliability. Features dual contact pins and nonpolar function for easy installation.
HP5: Four high-power SMDs, under a diffusing lens. Just like the HP3, but run at higher power, with integrated copper plating for superior heat dissipation, allowing maximum brightness.
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all vehicles.
Included in your order is TWO BULBS (to fit your Mazda 6).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Mazda 6 Sedan License Plate LEDs
194 LED Bulb Models
If you have any questions, please don't hesitate to post, PM, or Email [email protected]
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Diode Dynamics
Will these fit 2015 Mazda 6 ? On your website it says for 2003-2008.
Thx.
We are still in the process of updating the listings to include newer model year fitments (10,000+ listings on the site).
194 bulbs are indeed the most common size for license plate locations and should fit your 2015+ just fine!
Feel free to give us a call for more information: (314) 205-3033
Thank you!
Nick C.
License plate bulbs are used to illuminate the rear license plate on your vehicle. From the factory, the bulbs are incandescent, lighting up in a yellowish color.
You don't happen to carry this type of bulb for the trunk (interior) of a 2016 M6, do you? Looked on your site and only see through 2013. The '16 stock bulb is extremely dim, and your post made me think there might be a solution.
We have bulb sizes available for all Mazda 6's, we are still working on updating the site with more model year fitment.
Feel free to email us: [email protected] and we will help you find the best bulbs for your application
Thank you!
Nick C.
Discussion Starter #13
These look awesome and they solved my poor contact issue that was causing my incandescent bulbs to always blink out randomly. Here they are on my Mk. 1 wagon. Thanks Diode Dynamics
Our 194's have a fairly wide base to ensure proper, tight fitment. Those look great, and they definitely won't be coming loose!
Thank you for posting pictures, looks super nice!
Nick C.
Discussion Starter #14
Bulb dimensions are being added to our listings to help customers confirm fitment for unique applications.
Thanks!
Discussion Starter #17
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 12/2/2019, you can use coupon code "BLACKFRIDAY" at checkout for 20% off your entire order of lighting upgrades, including our NEW SS3 LED Pods!!! Don't wait, this sale ends TONIGHT!
Jake H.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday 12/2/2019. Cannot be combined with other coupon codes.
Discussion Starter #18
Don't miss your chance to save on all LED upgrades! Through Monday, 7/6/20, get 15% off all our LED upgrades for your ride, including our License Plate LED Bulbs with coupon code "JULY4" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 7/6/20. Cannot be combined with other coupon codes.​
Discussion Starter #19
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 9/8/2020, you can use coupon code "LABOR" at checkout for 15% off your entire order of lighting upgrades, including our License Plate Bulbs!!! Don't wait, this sale ends TONIGHT!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 9/8/2020. Cannot be combined with other coupon codes.
1 - 19 of 19 Posts
