Mazda 6 headlight connector replacement?
11K views 2 replies 2 participants last post by  Cathey
G
#1 ·
Yeah so finally the unfortunate happened and I haven't had much luck anywhere aside from actually finding the connector its self. The female disconnect connector (I think its called) that jumps between the orange supply wire to the actual headlight its self basically broke off after a couple of months trying to figure out whats been causing this headlight problem in the first place. Anyway I was trying to see if there's a cheap way around this IE just splicing the connector to the wire or do I have to go the long way and actually root from supply to headlight to get this all fixed up. Thanks all.
Specs:
2008 Mazda 6 2.3l I OEM headlights
#2 ·
