1 - 20 of 27 Posts
Hi guys.
My goal is to build a simple sound quality system and try to keep it all hidden and as OEM looking as possible.
The car is a new to me 2014 Mazda 6 Grand Touring Plus that I just got with 37,000 miles.
238959
238960
Equipment:
HU: Keenwod Excelon DDX9905s with the dash cam. (drv-n520)
Amp/Processor: Zapco ADSP-Z8 IV. Under the drivers seat. The controller will be hidden in the sunglass thingie on the headliner.
Front Speakers: HAT Unity U3 in the corners of the dash (80 watts) and U6x9 2 ohms in the doors (120 watts).
Sub: HAT Clarus 12 in an IB wall. (480 watts)
Sound deadener: The car is pretty quiet compared to my previous daily, so I wont go crazy on this. Will do a basic job on the doors and trunk.
238961
238962
J.
Discussion Starter · #6 ·
Weekend progress.
Got the camera hooked up.
Used tesa tape on the wires and ran it thru the rear view mirror plastic cover.
239053
239054
239055
Also got the center console done.
The car comes with a usb/aux plug and a charger.
239056
I got some USB extensions and replaced the OEM ones.
The right ones go into the HU. Top one does AppleCarplay. Bottom one will have a hard drive/usb with music.
The left one will plug into the Zapco. USB for tuning and the aux goes into the aux input on the amp.
The switch with the key is the "I dont trust you with my sound system" switch, which cuts the remote so the amp wont turn on.
239057
239058
This was my supervisor for the weekend, thats why I had a lot done.
239059
J.
Discussion Starter · #7 ·
Also managed to wire the Kenwood.
Found the workshop manual for the car online, so I repined the harness to get it to work (Reverse trigger and steering wheel controls).
239060
239061
GPS antena in the OEM location.
239062
Installed the microphone on the OEM location.
239063
Bundle of wires with tesa tape.
239064
HU in.
239065
HU working.
239066
239067
J.
Excellent job so far - keep it up! Can't wait to see the finished product.
Discussion Starter · #9 ·
Got the power wire in.
The OEM battery has a fused terminal which has and empty spot with a 60 A fuse that just so happens to be what the Zapco ADSP-Z8 needs.
239134
So I got a ring terminal and crimped the wire, got a 10 mm nut to hold it in place and used wire loom to make it look oem.
239135
Used the OEM positive terminal cover and it looks like nothing happened.
In case I blow the fuse, the entire fused terminal is $23 dollars and I ordered a new one just in case.
239136
Ran the wire into the cabin via the OEM plastic boot.
239137
Zip tied it in place with the OEM wires.
The run from the battery to under the driver seat is under 6 feet.
239138
As a side note, I was surprised to see what Mazda did to quiet the floor.
239139
239140
J.
Discussion Starter · #10 ·
Front speakers are in.
Stock bose speakers.
239237
239238
Old vs new.
239239
HPDE baffles.
239240
Wired.
239241
New home.
239242
Dash mat in.
239243
239244
J.
Discussion Starter · #11 ·
Door speakers
Used the oem baffle to trace it onto some hdpe cutting boards.
239245
239246
239247
Got the wires into the door.
The molex plug was a lot of fun. Not.
239248
Speaker in its new home.
239249
J.
Discussion Starter · #12 ·
Also got some work done on the IB wall.
Took the rear seats out.
239250
239251
239252
Added some sound deadener and foam.
239253
239254
Made a template out of some insulation.
239255
J.
Discussion Starter · #13 ·
Transfered the template to mdf.
239256
Test fit.
239257
Circle jig to cut the mounting hole.
239258
Test fit 345.
239259
Temporary Wiring.
239260
Test fit 348.
239261
Stock carpet covering the wall.
239262
239263
Still need to fix it properly and carpet it.
J.
Please come to this to my car :)
Excellent work and wish I had the time/skills you do because I'd love to do this to mine, except I haul too much crap to be able to give up lowering my rear seats lol.
Discussion Starter · #16 ·
Thanks, Byakuya.
Just pay my travel fees from Mexico and Ill do it. LOL.
With all the options out there... why 6x9's? What tweets are you using?
I used to compete in sound quality (both in Mexico and USA) a long time ago and was part of the Hybrid Audio Technologies Team.
When I decided to build a new car, I wanted to use HAT products and in that lineup the Unity 6x9´s do a really nice job as midbass speakers.
The next option was the Legatia line, but its way more expensive.
Im not using any tweeters.
The Unity 3´s are playing from 320 hz and up, the Unity 6x9´s are playing from 320 hz to 80 hz and the sub plays from 80 down.
All using 24 db per octave LR crossovers.
Need to break the speakers in before any tunning, but here´s a quick RTA I got with my phone of the Unity 3´s playing by themselves.
239264
J.
Discussion Starter · #18 ·
Finished the IB wall.
First ran the speaker wire.
239295
239296
Then carpeted the wall.
239297
239298
239299
Wiring the sub.
239300
239301
All done.
239302
239303
All thats left to do is to clean the wiring on the amp and tune.
J.
I wonder how or what is the sound quality with the subwoofer in that position as compared with the one that is located at the trunk.
I can't remember the thread title but he made a custom frame to fit the subwoofer like yours but it is located in the spare tire.
Excellent work! I’ll bet it sounds great!
This one? (Mine)
Stereo upgrade project 2016 M6 GT
My project was largely concerned with preserving as much trunk space as possible and keeping factory functionality. It’s a big step up for personal listening, but I would bet that running a larger full sized 12 IB is going to provide more bass than my sealed shallow mount 10. Of course my seats fold to the trunk and the op’s don’t. So there are definitely trade offs.
1 - 20 of 27 Posts
