1 - 3 of 3 Posts
I have a Mazda 6 2016 (66 plate) and I would like to add an amplifier and 4 new speakers as the system doesn’t sound great. I have no experience in completing an audio upgrade so any advice would be much appreciated. I’m a domestic electrician, so hopefully this will help a little.
To complete the project I will use a LOC (such as PAC-AOEM-MAZ2) and run the RCA cables including remote amp turn on wire to the amp.
From the amp I will then tap into the existing speaker cable and then connect new speakers in each door. Does anybody know how I can easily tap into the existing speaker cable, and where I would do this?
Thanks
Personally I would just run new speaker wires with the work it takes to find the factory wires and tap into them
The way I did this was to get another new red stereo harness and de-pin the 8 speaker wires on top. Remove the 8 speaker wires from the PAC-AOEM-MAZ2 and replace with 8 wires you get from the new harness. Run your amp wires to the new bare wires.
Everything is reversible and nothing would be cut and no running wire.
1 - 3 of 3 Posts
