1 - 7 of 7 Posts
my mazda 6 2009 has started a new problem. There is a vibration coming on speed between 40-60. below 40 and above 60 there is no vibration. Tyres are new and balances. Spark plug had been replaced recently. Transmission oil changed recently.Any one have any idea why this vibration happens.
Welcome to the forum.
I am guessing that since you are in UAE this is a 4cylinder petrol with a manual transmission?
Does it make the vibration in all gears?
Does it vibrate in neutral?
Does the vibration change if you are accelerating or slowing?
I m using Automatic
it does not vibrates in neutral
Vibration starts from speed 40 to 60 km/hr
more that 60 car is stable and smooth
if i accelerate in speed 40 or 50 the vibration is more.
CV axle is not replaced. the transmission fluid is changed recently. on of the shock absorber is jammed do it cause a vibration problem. the axle boots are already damaged
1 - 7 of 7 Posts
