Hey,
I’m having problems once again with my 2007 Mazda 6.
I’ve had a lot of seemingly electrical problems since buying the car. Here is a thread of a previous problem I was having:
www.mazda6club.com
I’ve been having more similar problems if the car stands for a day or two without use.
I went abroad for 10 days and when I was back the car was dead. Got a jump start and it ran fine for a couple of days. Then the battery was randomly dead once again (after just a few hours of no use). Got a jump start and got it home.
Tried starting the car immediately after turning it off at home. It would not start.
Now it’s behaving differently then in previous battery deaths:
- Dashboard lights normally but with all warning lights on. Stays that way. Same behavior in Neutral and Park
- Key fob remote doesn’t do anything and lock system doesn't work together on doors. Only the manual key to the door works.
- Radio does not turn on
- Nothing happens when I try to start the car.
- I’ve tried charging the battery for a few hours. No difference.
- Battery is just a few months old.
- On it’s last drive I did notice “ABS” and “slippery ground” light up. Might have been all of them but I just noticed at the last minute before parking.
I’m going to have it toughed to a repair shop in a few days but thought I’d check here if there might be a simple solution first.
This might be my Mazda’s last chance as I’m getting really fed up with these problems and have put a lot of money into repairs.
Thank you
Mazda 6 2007 won’t start / no crank
Mazda 6 2007 won’t start / no crank Hello, thank you for having me on this forum. Ton of info here but nothing that has solved this issue for me so far. I don’t have any experience with car tinkering so please don’t be shy to explain your thoughts as if I’m a 6 year old. I’m a Mazda 6 2007...
Thank you
