1 - 7 of 7 Posts
hello friends,
i have a problem with my mazda 6 2007.
When I am at a traffic light,
The rpm goes down for 600-700 RPM
Throttle cleaning and MAP cleaning did not help.
Thanks for the helpers
239823
Do you have any DTC codes?
Any other recent changes/maintenance done to the car?
First thing I would do is to thoroughly check for air leakages.
Small cracks in gaskets and vacuum hoses will cause this symptom you are describing, among others..
(╭☞ ಠ ͜つ ಠ )╭☞ r=1+sinθ
No DTC code.
It has been that way for a long time and nothing is done beyond routine care and replacement of spark plugs.
i think this is a familiar problem with these vehicles.
Isn't that supposed to happen?
It's important to note that when I'm running an A / C air conditioner - it doesn't happen.
No DTC code.
Sorry to hear about your problem. The "short-term" solution is to use your A/C. I remember having that issue with my CR-V 98 but I can't remember what we did to remedy it.
Did you fix your problem. I had Fluctuating idle and it was the front O2 Sensor. The way to find out is to unplug it and see if the problem goes away. If it dose then you know what to do.
1 - 7 of 7 Posts
