Discussion Starter #2
dies a mazda6 2003 have a fuel filter and where is i located in the car
it does.
Located on the pump unit assembly itself inside the gas tank. It takes a little disassembly to access it.
I should say... it's located IN the fuel pump assembly..
you'd have to completely remove the fuel pump assembly and then take that apart to access it.
People generally don't bother dealing with that and just replace the whole unit because when you start messing with plastics that's been siting in gasoline for years it often doesn't go so well. It's not impossible if you can source the items needed when things hit the fan and have patience..
