1 - 10 of 10 Posts
hi guys,thanks for making me part of the forum,nice to meet you all.
i have a mazda 6 hatch 2003 and the drivers side window died.I tried all i could checked everythingbut no good.I bought a window button box off ebay,i have all 3 windows (passengers) working now but the drivers window wont budge.No movement at all-just a dull "clunk'/click every time i pull button up or push down.Im wndering if the window motor is dead somehow.
Anyone have any FIX ideas?
thx for any help,its much appreciated
Thx for the reply DrFeelGood. No mate i havent taken the motor out yetor the regulator.The window does not move,and its doesnt make any motor sound or any movement like its jammed.It makes a dull clunk each time i press the window button.The window button box is brand new as the old one was faulty.I was wondering if maybe a loose wire or dodgy wire or a bad fuse.i was just wondering if anybody had a similar problem and possible solution.Thx for any suggestions appreciate it.
2004 Mazda 6s Wagon ATX
Sounds like your gear box is stripped and jammed. Easy fix, but if you have auto up/down, getting the right motor can be tricky cause people dont mark them as having 6 connectors vs 2.
@MadzMan This is quite possible. Living where you do, your market is the JDM cars. I think the difference is 6-pin vs 4-pin? If yours have auto down for the two front doors (auto 4 window vent auto up on front 2 possibly as well) then that is what you are looking for. The early (2003-2005) ones over here state-side (this would be 2002-2004 for you) were different than the "facelift" cars that came just after. All the early were basic 4 pin window motor switches.
Window Motor Replacement Tutorial?
MadzMan...
Yep, sounds like window "elevator" is bent or stripped.
ALSO, very wise since you have the window/door apart is to REPLACE window motor now ('cause they fail very common, one easy but irritating fault ).
At a breaker you should get window mechanisms cheap BUT get a NEW good quality window motor, you'll be happy you done it.!
PS, welcome...
Discussion Starter · #7 ·
Ill check out that tutorial,thank mate (y)
Discussion Starter · #8 ·
MadzMan...
PS, welcome...
Thx BikeProf ill do my research and try a new motor,thx for your help (y)
1 - 10 of 10 Posts
