1 - 8 of 8 Posts
I'm struggling to take out the turbochargers out of the Mazda 6, can't see 2 of the manifold bolts and also can't get access to split the top turbo.
What's the best way to get them out. Anyone got a workshop manual on it. I have the DPF off, bottom bracket, alloy intake pipe etc but cannot see how to get to bolts. Is this an engine out job?
It's unfortunate that very few members here have the diesel variant. Mine is relatively new, only around 56,000 km.
If I may ask, what's the problem? What happened that you want to remove the turbocharger?
Im pretty sure you only have one turbo also.
Nope, he's got two - 1 small 1 large. Mazda made a heck of an engine for non-North America buyers.
Unfortunately, I can't find anything about replacing them or any manuals. :(
Now I am reminded! The turbocharger assembly is composed of a small one for low RPM and the large one for high RPM. I can't remember the details but I think that's it.
These cars have two turbos but as a unit look like one. The reason for two turbos is that there is a small one with low inertia that spools up quickly which prevents the turbo lag of previous models circa 2000. Once up to a certain speed and gas flow changes over to the larger one smoothly so no lag up to 2000 rpm.
I would be interested on how the DPF comes out as I feel a good soak in soapy water would clean it out back to new. The soapy water routine I have used for carboned exhaust valves and turbocharger turbine nozzle rings with 100% success. Much easier than proprietry chemicals that are a bit nasty to the hands. All you are doing is adding a mild alkali to mild acid of the carbon and it just breaks up the carbon into sand like particles with time , say a few hours or overnight. If boiling water is used better still.
1 - 8 of 8 Posts
