While doing an oil level check I noticed a bubble on the engine cover beside the oil fill cap. I pulled the cover and can see that the nuts holding down the fuel return have gaskets with little legs attached to the gaskets below one of which is broken and there is a black mark on the pipe.
Looking for advice on whether this is safe to drive until I can get a replacement part or if this should be avoided and possibly a symptom of a bigger problem.
Is the bubble on the cover from leaking diesel?
Pictures of the engine cover, the broken gasket leg and a good gasket leg below.
