Hi I'm new to this so bare with me. I own a diesel 2.2 mazda wagon/estate. The car was running fine but had the DPF light showing. This light had been showing for 3 months now. After doing what the hand guide said twice I went to four different mechanics who said there is no problem with tbe DPF it may be a sensor fault. I decided to do my own research and found a video that said that when a service is done by non mazda specialists the people doing the service may not be able to reset the DPF It the showed a way to reset the light using a wire from the engine bay fuse box to any grounding point in the engine bay and pressing the accelrator 10 times. After I did this the light went. 5 minutes later when I returned to the car ever light on the dash board had lit up. The speedneedle on the speedometer had dropped and wouldnt go up despite the Rpms being fine. The power steering also stopped working the wheel will turn but it is very heavy. Can anyone help me?
i have the same problem
Hello
i have exactly the same problem.
how do you finally fix it?
Hello
Exactly the same issue to the letter. Did you manage to find a fix ?
I have the diesel variant and I'm curious on the solution. I'm running close to 50,000 km on my 2nd year of ownership this December. Since I regularly do highway driving, I don't see any concern on my part regarding DPF.
I've read an article that a clogged DPF is usually caused by city driving. It is recommended to do at least one hour of driving continuously at 100 kph to burn the accumulated particulates.
You are right, this shouldnt be ab issue with the motorway driving but the dpf lights come on anyway as a service indicator not necessarily meaning anything wrong with the car.
