I have a Mazda 6, 2004, 2.0D Turbo, 136 hp. The main issue is that it doesn't allow me to go over 1600 rpm. The check engine light is OFF, which is strange. There is a knocking sound while cranking, which I don't think that it is related to the main issue. There are the following error codes:
P0088-FF Fuel rail pressure sensor circuit high input
P0629-FF Fuel Pump A Control Circuit High
The fuel rail pressure is around 46-50 Mpa, not sure what it is supposed to be. The limit is between 0 and 200. All fuse boxes are okay and F18 (Fuel pump fuse box) was replaced as well as the fuel pump relay.
Live data during cranking and engine start up:
