201 - 207 of 207 Posts
Originally posted by kniep330@Oct 25 2005, 10:59 PM
So I just completed doing the mod and installed the MAZ/PC.  Everything went fine except for the fact that after about a minute of play time the sound all goes to crap.  Ive tried my ipod, my laptop, and the computer that I will be using for my carputer.  They all do the same.  The audio quality is great for about a minute and then it sounds like the speakers are blown.  It still plays the music, but there is a lot of static.  Everything else works fine except the EX1.  Any ideas guys and gals?
Thanks in advance.
[snapback]542590[/snapback]​
There are possible causes, please try the followings.
1. Check the wiring
Make sure that your connecting cable is propery modified. The connecting cable goes to HU must be modified at Blue Connector as follows:
http://sol20.com/ATENZA/cables_E.htm
2. Check the connector
Also make sure that the blue connector is seated firmly. You MUST push the connector until it is locked. New pins you just added are shorter than existing pins. If the connector is not seated propery, new pins do not contact with HU.
3. Noise Elimination Modification
Refer the following page for details.
http://sol20.com/ATENZA/maz_pcalp_noise_E..htm
4. Belkin adapter
There are reports in this BBS that Belkin adapter with Audio Signal Output solves the problem with iPod.
Please note, it costs and there is no gurantee that it solves the problem.
Just installed this in my 05 6 non-bose. Did the cable mod but did not need the HU L716 mod :D
Ordered:
http://www.discountcarstereo.com/detail.aspx?ID=445 for the interface.
http://www.discountcarstereo.com/detail.aspx?ID=124 for M-Bus to RCA adapter.
Installed with the XM Commander. The hardest part was getting to the HU. I reached behind the dash from the passenger side. It was a bitch and took serveral attempt to finally get the plug to seat completely. Sounds great and no engine noise :)
Thanks everyone for the info, and especially tickets...
